I have a transformer labelled as follows:
PRI 15,000 OHMS AT 5ma D.C.
plus a bunch of secondary taps, 62.5, 150, 250 and 600 ohms.
Can this be used for transformer-coupling a line output stage in a tube circuit? It's that 5mA specification that concerns me ... a little too low for tubes? And I'm guessing a cathode follower would still be necessary for impedance matching to the 15K primary?
then don't use it with dc, use it as a parafeed....the 5mA is not really low for tubes unless you are coupling to a speaker....then again......depends on the circuit you want to use....
