5AR4 @ 250mA
So thats where they all went. I only have a few hundred left....That's what I have been using and I haven't noticed anything nasty yet. I also find that it helps to float the 6.3 volt heater winding 30 to 50 volts above ground with a 0.1 to 0.5 uF cap to ground.
Well maybe not a million 😱 but I've got plenty. I am using a mu follower gain stage/cathodyne inverter, and have raised my heaters to 55V. Seems to work fine so far. Thanks for the info.
Scott
I first introduced the diode mod back in 2002.
My Power Supply Schematic with mods drawn in.
Original Burnedfingers
diyAudio Member
Join Date: Nov 2002 My Power Supply Schematic with mods drawn in.
Note: The first large cap is 850/475V
second is 330/500V
post number 32
"Quicksilver KT88 mono 60 watt amp schematic."
Put the diodes in the amps back in 2002 and their still working with the same rectifiers. It used to eat a pair of 5AR4's in 6 months or less. The diode mod works.
OK, so I installed a 1N4007 on each plate of the 5AR4 rectifier, after the series limiting resistors. Cathodes on the plates. Now the PT hums. I'm guessing that has something to do with half-wave now going to the plates.
It did not hum before adding the diodes.
