5687 load line
Joined 2009
What do you think of this load line?
OK, put a voltage doubler on the 150V tx to get ~350V. Use a 35K plate load resistor and a 1.4K cathode resistor.
For even better performance, a 300 ohm cathode resistor and a CCS set to 20mA on the same supply would be nice.
For lower voltage operation, a plate choke is a good way to run a lot of current through the tube without having to use a really low value plate loading resistor that screws up THD.
I have a hybrid mu-follower from Ale Moglia that can be set to 20mA🙂. What soud be the B+ before the hybrid mu-follower & what B+ after to the plate?
I look for if I have any 300 ohms for cathode resistor: what's the grid voltage?
Also I have a couple of OPT but I like more the hybrid mu-follower.
Now I have 3.3V battery bias to the grid.
That's the PSU with voltage doubler?
