Hi, I was wondering would it be safe to run an amp that uses 2sa5200/2sc1943 outputs on 100-0-100 voltage levels?
I have 4 channels , two use original Toshibas with rated max CE voltage of 230v, the other two use Fairchild's analog's with CE rated at 250v.
what do you think?
what do you think?
