I'm cleaning off my shelves. Powermate analog, regulated 50V enclosed power supply, with the output trimmable from an access hole from 45.5 - 55.4VDC. The input rating is 115V/12.5A. I used an 18 ohm test load and the no load and loaded output voltage read 50.0 volts. I think the units should be good for 8-10 amps out.
There are two units available, measuring 5"H x 7 1/2" W x 9 1/2" D and weighing over 19 pounds.
WIthout further testing, $20 each.
