50hz on 60hz power for tuners
It won't matter for an analog tuner.
fyi - for electronics that travel across the Atlantic: I have a European Marantz receiver (lovely unit) which is all analogue and I also have a British Sansui tuner (also lovely and I swapped out the power transformer to make the unit native). Both of them were set up for European FM de-emphasis which when used in Canada produces excessive upwards tilt in the audio frequency that is most notable - too bright, too much treble. The de-emphasis filter is implemented on both units as simple passive circuits. I believe Canadian de-emphasis is the same as US.
