Sakis,
I don't know how you interpreted my comments.
Upto after that everything is completely different. I cannot seen any agreement nor similarity in our approaches to understanding what is going on !!!!
never said that our approach is similar .... i just tried to say that your calculations about thermals, efficiency , consumption , and power output are correct as usual ... ingenious is on the same path i think ....
i only wanted to point that real life commercial amplifiers are not constructed under the same calculations or aspects
your way of thinking might be more than hifi and a flawless design .... only its not actually possible to produce due to size and cost ....
I found this old thread that shows a low(ish) budget way of putting together a power supply for a big rig:
http://www.diyaudio.com/forums/solid-state/61422-arc-welder-transformer-used-power-amplifier.html
where did you source input power = 6kW?For 120V rails, output power is 3000W into 2 ohm,
The input power is about 6kW, so we are nowhere near the theoretical efficiency - as predicted by AndrewT.
How can you arrive at a theoretical efficiency, when you appear to be quoting/stating real values?
Oops - that is the peak value. For RMS, divide by 2. Both positive and negative rails supply that, but not at the same time. For purposes of efficiency calculations, do you add them together?
LTspice gives the peak values as 6,15kW into the 2 ohm load and 6,60kW for each rail supply. I calculate the efficiency as 47%. Am I getting this right?
pcb
sir, have you its pcb or layout.
Tekko is on to something. A quick look on Yahoogle turned up this beast for $450 + shipping.
Gemini XP-6000 Professional 6000W Amplifier
It is rated at 600Wpc into 8 ohm with 0.1% THD. That's a lot of power for the bucks.
Is it possible to beat this price in a DIY class B project?
You will need two 1000VA transformers:
And two (no, make that that four) 0.3K/W heat-sinks:
Lots of these:
And don't forget these little suckers:
By now we have blown the $450 and the shopping list is still quite long...
- 500W RMS PA Amplifier
