hello apex, i just want to ask if i can use the b500 for my home theater sub or do you have any suggested amp to build...
Julius
Apex has left the building.
^ probably apex is too busy to come to the boards and answer your questions..............
i know the feeling, when something you love to do becomes a chore.......been there, done that..........😀
i see.... anyway, anyone can suggest a subwoofer amplifier that i can build for my 400 watt 12 inch sub from the apex line of amplifiers
i think you can build his quasi for biggineramp. its easy and cheap to build... but the b500 is much better for sub im my opinion . i have tried it already...........
thanks jon2xflash. i might be building one b500 myself... 2 spl side firing boxes in progress. apex b500 will drive them loud for sure! 🙂
Mr mile/apex.......
Can you share to me and all of diyers schematic triple darlington
sorry mr .mile i mean is the lay out.......on pcb.....
Ask mile :This circuit can be use to switch any stereo amplifier to bridge mono mode.
BX500 have balanced input, but without bridge option, use this circuit if you want use BX500 in bridge mono.
if me will implementation with apex b500 stereo bridge to mono,share wiring more detail....
thanks
my first b500 experiment.... its nice good sound quality thanks to sir apex....i had encounter trouble when i turn on my b500 1st the the circuit was shorted fuse of the psu burnout i check all the connection and the parts i notice that some parts interchange like the transistor 340 & 350.... affected damage transistor was mje 15033 15032 and resistor 100 ohms... what i did what i did place the 340 350 to the exact place and im using tip41 and tip 42 is okey sir apex its working fine and good quality sound i like it......
thanks alot... regards rompi....
mile where are you...i need result abaout my question (about apex B500 routing BTL )
regard
Azka...Mr.Mile haved sharing schema BTL or layout PCB a long time ago. You can find its on title Apex B500 or Apex H900..
my b500 from Apex is nice sound. like sonic
my first b500 experiment.... its nice good sound quality thanks to sir apex....thanks alot... regards matsazilin....
- 500W PA amplifier with Limiter
