Hi all you power amp builders
listen to this:
Im planing to buy transformers for my GB300D project (Greg Balls MOSFET amps)
Transformer is custom made for this Audio project
Transformer specification:
prim: 2 x 115V
Sec 1: 45V @ 5.4A
Sec 2: 45V @ 5.4A (bifilar wound with Sec 1)
Sec 3: 12V @ 1.2A (for loudspeaker protection circuits/relay/lamps etc....)
Total output power of > 500VA
The transformer will be vacuum-potted in a mild steel-can painted black
Low Flux Density for minimum noise output
Flexible leads (300mm) 180 degrees between prim and sec. leads.
My specification to the transformer company was that this transformer should be dead silent when delivering full power (for class-A amp. projects).
Pricing so far shows
1-4pcs: £ 105.00
5-9pcs: £ 99.50
10-29: £ 89.00
Lead time when order is placed/payed: ca 14 days
NOT including in the price is the local VAT/MVA/MOMS, and shipping/handling
Is this a decent price or is there better alternatives (Plitrons transformer was priced 3 times higher than this for a 500VA transformer)
If any interests please PM me. (I have a PayPal account)
listen to this:
prim: 2 x 115V
Sec 1: 45V @ 5.4A
1-4pcs: £ 105.00
5-9pcs: £ 99.50
10-29: £ 89.00
Could make changes to the Voltage-output
Okay, the response so far to a GB of the 500VA transformer was low so............
I could change the output voltage if you like, so... I would like you to make suggestions to what voltage could be beneficial for you. For my own purpose it works if voltage is between ca 2 x 30 and 2 x 45V (total: 2 x 250VA).
