~50 Watt Amp for a Beginner
i did not say it is the best choice,
it does not meet the 50 watt requirement.
it does meet supereasy, cheap, stereo, able to drive 4 ohms.
it is a first amp build.
i sense this build loud enough, surely can't say if it would be the case for everyone out there.
there is an easy way around it, prehaps.
McFinkle, what are You going to drive with the amp ?
is it sure 50 watts is needed? (is it 50 watt RMS or peak btw? )
I was also looking for an easy to build amp and ended up creating from lm1875 and lm3875 (lm3886). These are easy to build, chips has some self pritection. If you can take care of it, then you can build a really few item count amp with good sound. If you search for gainclone you will see how simple these are. You can "complicate" them with safety stuff, but it is not necessary.
