48v power supply design questions
I am working on a hybrid amp that requires a 48v 350ma power supply. I have a 24v 1.5a transformer that I would like to use. I'm just having trouble getting from 24v to 48v. Power supply designs are my week point. I'm learning as I go. Thanks for any help.
Bryant
that voltage doubler circuit he's suggested is not a good idea for a high current supply. They work well at low currents but not at 350mA.
The 24Vac with a voltage doubler will give almost 70Vdc on very light load and as the load increases the ripple becomes enormous causing the average voltage to fall.
Most of the designs that I have seen are the voltage doubler type and as you say the ripple makes it almost useless at that point. I found a 48v 3a transformer but am unsure how to get the amps down to the level I need. I know it's just a matter of adding resistors and capacitors but in what order and where. Right now all of those formulas I had memorized are just gone.
...... I found a 48v 3a transformer but am unsure how to get the amps down to the level I need.
the circuit/load will draw as much current as it needs. Do not try to reduce the current, simply satisfy the demand.
A 48Vac 3Aac will give you 65 to 75Vdc and continuous output of 750mA and stay cool.
If you want 48Vdc you need a 33Vac to 35Vac transformer.
I think Andrew's replies have been the only useful ones so far.
I'm all about trying to use parts on hand. You could use your 48VAC transformer and a simple transistor regulator to drop the ~70VDC unregulated to 48VDC. You'll need a fair heatsink on the transistor, it would be dissipating about (70-48)V * 350 mA = 7.7W.
Here's an example:
zener regulated power supply
Here is two circuit.
1. Simple circuit.
2. A little bit complex to reduce capacitor size.
Hope your solution you got.
