Yes, a step up converter will work. They have more or less 90% efficency, so that shouldn't be a problem. But if you buy on ebay or Ali, make sure that you read the specification with a critical eye, they are suspiciously cheap and max power can often only be used with additional cooling.
Still, you can't input more than 40V DC to a TDA8954 unit, so max output still applies.
Thanks, this is really helpful! They certainly are suspiciously cheap.
I think I will have to ditch the TDA8954 as it seems too niche or convoluted (and inefficient) to step up and convert DC from a battery to dual AC as required by the TDA8954, which is a shame as I already bought this amp.
Can you recommend a reasonably priced/quality alternative amp that will run on DC at 40-45 volts?
maybe here...:
200W IRS2092 Amp for $20
chris
That one's also dual voltage.
ahh... sorry my fault
maybe a TPA3255 chinese board?
Have a look at this board http://store3.sure-electronics.com/...udio-amplifier-board-compact-t-amp-sta-516-be. Up to 50 volt with a lot of batteries .
The T-AMP versions sounds really nice, I have one of those stereo amps and they are perfect for a home theatre system. Lot of bass and a very catchy sound.
Not as neutral as the TPA3255, but overall nice.
hi eshamp
you want a ready amp or board?
if you want to have a TPA3255 ready amp...here and pages before are some discussions: anatoliy was at the beginning not really happy..but read...
https://www.diyaudio.com/forums/class-d/287470-tpa3255-diy-discussion-design-etc-107.html#post5739410
the TAS board i an digital chip baord- so i guess you have an additionally DA conversion on that board....its not needed.
TPA3255 board stand alone:
1PC New Arrival Class D TPA3255 MINI HIFI AUDIO Digital Amplifier Board 300W + 300W DC50V Module-in Integrated Circuits from Electronic Components & Supplies on Aliexpress.com | Alibaba Group
thread:...pages before are interesting too
https://www.diyaudio.com/forums/class-d/309813-wrong-tpa3255-30.html#post5499268
chris
hi eshamp
chris
Banggood won't let me cancel so TAS it is. I'm not sure what you mean by DA conversion?
Take a look at TPA3255.
Run two 24V for 48V...no need to split supply.
TPA3255 will run 18V to 50+V
Is there a limiter switch setting on the TPA3255? I set mine up with a 53v 600w DC-DC powered by a large 12v Pb-acid deep cycle UPS backup battery. Using a 200w 4ohm load resistor, I was only able to get 40vpp before clipping. This is not even as high as the rail voltage, I monitored that and it did not sag below 53v setting.
just an idea: without experience...sorry i am not an expert
DC-DC converter has an efficiency of about 85% at this power output....=> 53V *0,85 = 45V
this 45V with an efficiency of 90% of the amp = 40,5V
chris
That's not how it works. The voltage stays the same until it's exceeding the current limit of the PS (SMPS, transformator, battery, whatever). If a PS or DC converter got an efficiency of 85% that means the remaining 15% of the 100% are going to be heat. That means, they will draw 15% more power than they will supply, the input current is higher than the output current. It does not change the output voltage, at least not if the input does not sag because of the current.
ok. i was tooo quick in thinking. yes you are right. thx
but now i am interesting....what could the reason of the voltage sag??
It could be the power source not being stable enough, serial resistances of the wires, switches, relays, fuse, transition resistance, current limiter or protective circuits, lack of heat dissipation.
Just follow:
Voltage drop is 13V (53-40).
Load: 200w ,4R = > P= I^2 *R........I= about 7,07A
Voltage drop R = u/I 13/ 7 = 1,83ohms "loss" serial resistance?
chris
Just follow:
Since power supplies also got inner resistances and there are likely also contact resistances at the cable mounts involved, that sound pretty feasible. The dimensions of the buffer capacitors and the ripple/ESR play a factor too. And don't forget, no PS works without losses.
thanks for sharing your experience
- Class D
- 420W TDA8954TH Overkill? Lithium powered project
