400 watt metal halide ballast....
Ok,
I just bought a 400watt mh ballast from www.1000bulbs.com. I also bought one of the giant bulbs for it, but I'm wondering if I could buy a smaller bulb for it? Like one of the tube bulbs for aquariums.
I thought that I could mod an ohp with it, but now I want to see what other bulbs I can use with it.
Any suggestions?
Newpaltzwonder
Ballast info: $45.00
ANSI M59 or H33, Operates (one) 400 watt Metal Halide lamp or (one) 400 watt Mercury Vapor lamp only. The only Pre-Wired ballast for easy installation. ISO-9001 rated. Engineered to produce less heat than any other ballast. Kits include mounting bracket, capacitor and ballast. (No minimum order, priced individually) Warranted for 5 years from invoice date.
Right on man, i want to do the same thing. Akeem's projector 0wNz0r.......want to follow in the footsteps.
How much success have you had w/ modding the OHP due to the larger bulb?
Did the larger bulb create any problems for you?
