4 woofers crossover, is this sound?
With some eq they get down to about 40hz in room and hopefully the 10" drivers will go a few hz lower. I am aware I could do better with some acoustic elegance drivers. But these are less than 1/13th of the price per cm2 cone area. Only drawback of these is that they aren't properly ventilated so when you push them there is "wind noise". But I am not complaining for 6 bucks per driver.
I was off in my math.....it is more like 1/30th of the price compared to acoustic elegance OB drivers.
Yes, sorry...I meant to say that if two woofers sharing the same path, say the first low pass filter ( I guess the second LP would be cascaded), and you want only one to emit the midrange, just cover the other one to make a mechanical LP filter. Probably just a disc centered, because it's near the voice coil that there's maximum treble emission
Reactions: wchang
