4-way speakers
i understand what you say and thanks for yours advices.i won't build something like this on my own,there are other people behind me who can do this.my problem is that i can't know what parameters should the drivers have(tweter,mid,woofer and sub).the same impedance sure but what about the others(power,spl)?
we know that the hole project is very difficult and specific but we are about to build a 4-way cone shape cabinet with bass reflect speaker system.
is there anybody who has already do something like this?or some pics if you have about this project?
thanks all of you
If you're going to multi-amp your speaker system, all your impedance, puwer etc. problems come down to "will this driver get loud enough for the reqired function, with adequate quality" All other details can be taken up electronically. If, however, you are planning on a passive crossover, trying to match components that are not sold as a set can be extremely complicated, particularly if you don't have access to sophisticated test gear. (it's complicated enough if you do) Most manufacturers of bass loudspeakers will give you porting details for their drivers; were you considering integrating the subs into the cabinets?
Fortunately mid and high frquency drivers are reasonably non-critical about cabinets, (well, apart from hard corners and things), so it's only your bass and subs that are attempting to shake the cabinets (and crossover components or amps) apart; use more glue than you think can possibly be nescessary, then add some; more amateur speaker cabinets are spoiled by rattles and buzzes than ever miscalculated ports. Phase? (yes, it is important, particularly at crossover points, of which you have many) vertical alignment, particularly cossover components (if you get inductor coil buzz, it's a pig to get rid of ; it is possible to do better than any of the mass-produced cabinet manufacturers, but only because you're willing to put indefinite quantities of time and effort into a small run, which they can't.
If we figure that each driver may cover a little over two octaves it becomes clear, that the HP and LP will be closely interacting in the case of the woofer, and of the midrange. The sub will also be interacting with the mid, and the woofer with the tweeter.
A 4th order setup will undoubtedly not make things easier.
It will of course be possible to choose drivers closely suited to their bands, but more difficult to match them to each other.
If you can overcome the problems, I think you'd have a sweet speaker. Good luck.
1. Bass/midbass - go fore a 6" driver well suited fore a two-way, it will take some power, and you can place crossover point "high"
2. Find a midrange with a smooth and high extended frequency responce, around 10khz before rolloff with out peaks - so you can place crossover point above 3000hz
3. Buy the best tweeter you can afford
It should be possible to reach 90db
What is your budget ?
4-ways speakers
thank's for the information that you give me but my question is very simple.I want to buy the drivers but I do not know the proportions that should they have like watts and spl in order to collaborate rightly and I have right level of intensity in the all acoustic spectrum.give me an example for a loudspeaker 100watts rms.
watts spl
tweter / ? / ?
midrange / ? / ?
wooofer / ? / ?
subwoofer / ? / ?
Re: 4-ways speakers
Your trying to pair drivers based on manufacturers rated sensitivity?
I'd have to very very strongly echo Rich's comments here, go out and buy a couple of good loudspeaker design books, build a kit or established design, anything but waste money on this proposed 4-way. By the sounds of it you don't have knowledge to pull it off.
No offense intended, I'm hoping you don't waste money that's all.
4-ways speakers
I have not something specific in my brain.no problem with the cost of the drivers.the initial idea it was to made a 3-ways loudspeaker but we want to add also subwoofer in order to cover bigger spectrum of frequencies.the problem is that we do not know to calculate the watts and spl that should have individual drivers in order the loudspeaker has the same correspondence for all the frequencies.
Re: 4-ways speakers
You can level match drivers using resistors if going passive, active is just a case of gain.
Look at cone materials, impedance, optimum operating ranges and natural driver rolloff to start off with. If you don't fully understand all of these things then I strongly recommend either scaling back to a simplier 2-way to get a feel for this or just buy a kit.
Don't obsess over sensitivity between driver units, its a small part of the equation to getting an overall good sounding multiway speaker.
Well, if you want a speaker to cope with 100watt you need expencive drivers or PA like - sounds like disco level to me
Another way to get high SPL is to design a high sensitive speaker, so you get high SPL with fever watts - but not very easy
Generally, if you imagine two drivers crossed around 300hz they will use/handle the same amount of power
If you cross a tweeter very low there will be bigger risk of burning
Likewise if you cross higher between bass and mid there will a better chance the mid will last, and woofers usually have higher watt ratings
Re: 4-ways speakers
Glazarou,
Maybe simple to you, but the answer is highly complex. Based on your information you have provided (or lack thereof) us to assist you, I would venture, if we gave you all the answers (with much energy and many assumptions on our part), you could only absorb a small percentage at this time. So, start your research and ask simpler Q's next time.
