Hi everybody,
I want to build a balanced input switcher for up to 4 stereo inputs and, if possible, not degrade or alter the audio signal.
What would you recommend, a relay or multiplexers solution? Is one better than the other in terms of audio quality?
I am very pleased about any concrete suggestions
Thanks!
Thanks!
Sources will be any DACs with balanced output a MOTU M4 right now, load shall be this board MUSES72320 Volume Control Board with Ground Sensing Output – hifiocean with an input impedance of 47 kOhm I believe.
In my previous solution with only two unbalanced inputs I used two relays but I'm wondering if there is a more elegant solution than to put relays in series.
I would like to control the switcher with an arduino.
