360VA Toroid
Theory of how to wind toroid transformers.
Size and material of core
Wire dimensions
Number of primary turns
Number of secondary turns
Fixation of the windings
Aside from getting it all right,
I do not think you have much money to gain from wind your own trafos.
How come you think of doing it, instead of buying?
start with a pre-wound primary. It should be tested as well.
DIY allows you extra windings exactly matching your requirements.
If a standard pair are good enough then then buy ready made even secondhand, eBay is a good source.
360VA will allow about 180 to 260 Watts of amplifier output. Translated into two channels this equates to 90W+90W upto 130W+130W of continuous power.
There are a number of sites giving winding info and some previous threads here on DIYaudio.
Try:
www.toroid.com. There is a bit of theory on the Kits page. Notice the "Kits" page. They give you what you need, except for magnet wire.
I am looking to build an integrated amp, and the custom aspect of winding your own is appealing for that.
Also, I did find a site that had all the calcs you need for transformer design...I'll look for it again...
as a rule of thumb, divide the VA by 1.5 to give the maximum power output. 200VA > about 130W.
Decide on the minimum load impedance you want this power to drive. Vpk=sqr rt(P*R*2). Add on some Vrail to Voutput loss, say 6Volts, giving a Vrail = +-(Vpk+6).
Vac = Vrail/1.414
For an 8ohm load then Vac=36Vac to 37Vac.
The unloaded Vrail will be about 8% higher than loaded Vrail and at peak mains incoming voltage you should allow about +6% again or a higher figure if you know the tolerance from your supply company.
This max peak value determines the working voltage of your smoothing caps (63Vdc).
