If your system is really +ve, +ve return, -ve and -ve return, it may be better to put in two GND wires and twist +ve and -ve circuits separately.
If the current is really flowing from +ve to -ve andd GND is just a reference, it may be better to twist +ve and -ve, then wind GND around it.
If it makes that much difference, you are sailing close to the wind....
They're both sort of in the middle. The CCS uses GND only as a reference, but the load is so small that the reference current is 50% of the load current!
In the PSU case the signal current goes from +23V or -23V through the load to 0V, while the quiescent current goes +23V to -23V (with only the locally-filtered ripple going to 0V).
It not just signal currents that need to return to source.They're both sort of in the middle. The CCS uses GND only as a reference, but the load is so small that the reference current is 50% of the load current!
Interference, noise and the unbalance of the rail quiescent currents will probably return to the source via the zero volts connection.
If any of these varying currents pass around a loop they will emit EMI.
Constant level DC cannot emit EMI. Varying level DC is a varying current and will emit EMI.
A power supply that is +ve and -ve is a single polarity supply.If your system is really +ve, +ve return, -ve and -ve return, it may be better to put in two GND wires and twist +ve and -ve circuits separately.
The supply sources a current and must by the laws of nature sink that same current.
Where there is a Zero Volts line from a dual polarity supply, then some current will return to source via the Zero Volts line. This requires that the returning current be close coupled to the source line to minimise EMI.
- Power Supplies
- 3-wire power: twist or braid?
