Not exactly the drivers you want but the Ekta is well thought of...
http://www.troelsgravesen.dk/Ekta.htm
You could always add a Peerless XLS or similar as an active sidefiring woofer if you wanted more bass.
How low do want it to go and how loud? The 18W gets down to about 40Hz no problem with reasonable power handling so long as you keep the level fairly sensible. If you're going to use it for HT you can send all the really low stuff to the sub
I've used the SS 12M, paired with XT25 and 8565-01.
I measured the 12M quite close to the published spec, an easy to use mid.
http://www.diyaudio.com/forums/showthread.php?s=&threadid=76176
- 3-way Scan-Speak
