3 pins capacitor
It's actually not exactly 2/3 but 1 - 1/e where e = 2.7182818284..., so 1 - 1/e = 0.632120558...
Nigel proposes to charge instead of discharge the capacitors via a resistor, but charging to 1 - 1/e times the voltage or discharging to 1/e times the voltage is completely equivalent , except for the effect of leakage currents. Those would lead to a somewhat too high value with Nigel's charging test and a somewhat too low value with my discharging test.
Anyway, all the values you measured in post #33 are a bit higher than the capacitor's nominal value. That could be due to dielectric absorption, see Dielectric absorption - Wikipedia , or maybe the capacitors have a skewed tolerance interval, like -10 %/+50 %. In any case, it shows that they are not dried up.
I was surprise they charge to 35v. in less than a minute.
! minute is still near the time constants involved and does not tell us much about *health*; if anything about *capacitance*, nice to know but not the main issue today.
they are reformed or partially reformed.
Yes.
After 15 min. they are all at 32.6 or 32.7 volts
Just check again after 30 min. 32.0.or 32.1v.
Ok, that tells me thay can be safely used at 28V rails, where LM3886 is very comfortable.
Of course, at +/- 22V even more 🙂
I saw elsewhere in this forum that we need to keep the voltage 20% under the rated voltage. Right on at 28v. 🙂
I need to take note of all those formulas. 🙂
''skewed'' may be in the way of fabricate say 12,000uf capacitors and print 10,000uf on them to be certain people don't complain they have less. I think Roederstein was a reputable compagnie at the time and they want to keep it that way.
Anyway I can go to work with them... or play , it's a hobby that I like. I find it relaxing to make something with my hands, not just the electronic but working on a case too and trying to understand what's going on in all those little composantes is interesting too.
Have a good night/day
