3" Driver in a Transmission Line.
As some of you will know, I've been using some Visaton FRS8s in open baffle speakers, using one in the baffle and one to cancel the rear wave.
I was curious about making a (fairly) small TL for them to see how they perform. Some say TLs shouldn't be tuned below driver Fs. If this is true for all projects, this will be a waste of time (Fs around 120Hz for this driver).
I am doing this to learn, as many like the sound of horn/TL speakers, and I wanted to know what made it so brilliant.
Link to the driver - http://www.visaton.com/en/chassis_zubehoer/breitband/frs8_8.html Parameters are also there. In winISD, they don't model hugely well (tried vented, sealed boxes), so I wondered what would happen in a more elaborate cabinet design.
Thanks in advance for any tips (even if it is simply to say "this won't work")
Chris
Chris, as I suggested to Kipman, personally, for something this small, I'd use an FRS8M as a full range (bit more efficient than the FRS8) & the WS130 for the low end (< 200Hz). You will only be able to get an EBS alignment happening for the FRS8, and to use eq to get reasonable bass level will push such a small driver beyond its capabilities. You'll get much less distortion going 2 way (& these drivers are pretty cheap...)
