3,5kΩ 50w push-pull transformer.
I believe that we are re-opening an old debate on the gu 50, namely the OPT and the screen voltage. I read on this site that in triode mode and in BF the screen could take 500v ... On the other hand, I have seen very complicated OPTs with several windings. I am not sure of my 1.75KΩ (Raa3.5kΩ) load line but at vg = -20v, P = 26w (215v, 120ma) which is 0.65xPmax.
You can not get more than some 20 W from a pair of triode connected GU50 if using 3k5 load impedance.
400 V as +Ub and some 100 mA plate current produce the plate dissipation power that can not be exceeded.
With these conditionds, especially with +Ub = 215 V you get very little power out, maybe 5 W, which is a bad joke for a pair of GU50.
Damned! i calculated 6w. I mistakenly thought that an amplitude of 145v would be comfortable. But with a transformation ratio of 20.91 it gives 12w per channel (unless I'm mistaken). maybe I should choose -30v to get slightly more.What a misery!
