This is a recent build that was a Christmas gift for my in-laws.
Here are the basics:
Sounds really quite decent from my testing. It will not be used for loud volume or more "intense" movies so will likely be used without a subwoofer.
- Intended for wall-mounting
- 3.0 (Left, Center, Right) /w one full range (pluvia 7) driver per channel
- Left and right channels are ported /w 7.5 liter enclosure, center is approximately 3 liters sealed.
- Intention is for L/R to be configured for full-range signal, center channel to be run with high pass filter at 100 or 125 Hz.
- Constructed from half-inch Oak plywood with solid oak edge/frame.
- All wiring terminations are on the bottom in the center. 3 pairs of gold-plated binding posts.
Nicely done - reminds me of a similar project a few years ago using A6Ps, with a pair of separate enclosures for rear surrounds, and CSS SDX7 subs for a full 5.1 system.
Hard not to suggest that adding even a small powered woofer and full bass management via HT receiver would make a huge improvement, but if this for in-laws, that one extra remote can be a bridge too far.
My logic was that since I had limited volume I'd rather have the main stereo pair has reasonable bass extension rather than having all three with mediocre extension. As well, this way I can cross over the center speaker to the stereo pair to reduce its workload and hopefully improve clarity on the most critical speaker for overall sound quality.
I can't say I've compared or listened carefully enough to notice the effect though.
Pass DIY Addict
Joined 2000
I’d be inclined to posit that when run through “proper” surround DSP, the differences in processing / mixing between the discrete centre and front mains would mask whatever those sonic signatures might be. I guess the quickest way to test that hypothesis would be to play a full mono signal of familiar material with the solo centre on speaker A, and the L&R on B, with levels matched. Never needed/wanted to try that out, so entirely a wild aztec guess.
- Full Range
- 3.0 MA Pluvia 7 Wall-Mounted sound bar
