2SK180 mounting ideas
I want to have an idea of where and how I am going to mount the 2SK180's before I start designing a PCB. The THF-51's and 2SK182es seem to be pretty straight forward but the 2SK180 looks a little wonky to mount. I would love to hear your thoughts and ideas!
If I use my 2sk180's this is how I'm going to mount them, it allows a good heat path to the heat sink and the PCB's can be located anywhere to suit the case and other components. Connections can be made using high temp cable before the device is screwed onto the mounting plate (insulating pad omitted for clarity). The mounting plate shown is then fitted onto the heat sink with screws to suit.
Bren, rephrase the question. Tokin is 'panel mount' only, and must be connected by drain/source via decent wire.
edit, perhaps his metal machining method allows access to thread wire, and maintain the thickness of the total material. The source connection of an sk180 extends about 12mm or 1/2 inch.
In the 2sk180, the leads poke out of the mounting face unlike the 51s etc. I may be possible just to put two plates together, and drill the holes instead. When removed you have two semi circular channels.
Sometimes a good amp requires the parts to be hidden. Low ego, max enjoyment. Feel free to hide them in the coolest location needed. TO3 can type mount presents that dilemma, esp. at 30+ watts per device. A well-seen 'bracket' is simply eye candy, a worst case and never as effective. In this instance, a 'can' should mate the outside and speak to the inside, hence the form.
In a now old article, Nelson presented his version of a JLH amp (PLH). Now, forget that circuit for a second and scroll to the product. That chassis is a 'can' chassis. Plate aluminum, with rec tube. Perfect for the cans or otherwise. Build to your content. Spray it rustoleum and wet sand to your wish. You can even make that from retail metal (2-4$ lb.) and your crosscut saw. Tap with a drill press and your own imagination.
5 pounds... 17 pounds of aluminum. Its your wish. (IME each 1 lb is good for 10 watts)
The point is, who cares what it looks like. That's what you'd say?
But then you care what it looks like.... so do a good job.
I thought I would post to show a finished article. It's just some bits of 15mm aluminium. I've cut them on a pull saw using a cheap ali cutting saw blade, seemed to work ok even for cutting the wiring slots, (do wear safety glasses as the swarf flies everywhere, and take it fairly slowly). Obviously the blocks can be any size, these are 100mm x 70mm. I intend to directly fix the VFET to the block, uninsulated and then use mica sheets and shouldered screw insulators to mount the block. This hopefully will help with heat transfer. As is usual the VFET is held on with M4 screws, the block to heatsink with M6.
Thank you ZM. It could look "Fuglier" if milled, but I was trying to make it in a way that was possible to many others. Just a drill and a saw. (I imagine that a router would do also). What surprises me now is the low cost of Chinese carbide cutting tools.
