Hello everybody!
Short question: are there any cutbacks using 2SC3182/2SA1265 instead of 2SC5198/2SA1941? What about using them mixed?
Reason is that in my Amplifier 3 2SC5198 out of 6 are broken and in Germany its quite difficult to get 2SC5198.
Thank you!
Thank you!
What is this for silly question? You can see yourself in datasheeet that they are almost identical.
i know, main intent of my question was if i can mix up 2sc5198 and 2sc3182, as even transistors of the same type should me matched as close as possible. i think i will just replace all of the transistors for 2sc3182 to be sure it will work
why did the 6 break?
Fix that before you power up.
it was just overload. bridge mode into 4r0 wont last long. driver transistors are okay
