2N5952 Pinouts
The thing about JFETs is they are ON - relatively low resistance source to drain - until turned off by a voltage on the gate.
So get out your ohm meter and measure resistance between the three pairs of two legs. The two legs that show low resistance to each other will be source and drain. The third leg will have very high resistance to the others, or measure as open. That is the gate.
Hello Ken,
I have the same question so I sent an email to Central. I will post here when they answer.
I have done the same due dilligence, just for CYA. It will be interesting to see who gets a reply first, if at all. In the meantime, it appears there's enough info in this thread already for me to forge on. Will be breaking out the multimeter and checking some resistances.
What is the roaring and screaming about? This is a JEDEC registered part number, there is no latitude whatsoever for any alternate supplier to reassign pins. End of story. The Fairchild data sheet its a good enough reference to proceed.
BTW, even for non-JEDEC parts, alternate suppliers won't monkey with pin assignments, but will tweak other parameters to their advantage instead.
Hi Ken
I got a reply from Central Semi.
See chart below.
Mr Wrench,
The confusion I had was due to conflicting data sheets from Fairchild and Texas Instruments. Central did not have a pin-out on their data sheet.
