2d3t wiring diagram?
I use a 3 position, 4 circuit rotary switch to do the same thing. Only 2 of the circuits are needed for the audio, LEFT & RIGHT. The outputs are the center pins, the inputs are the outside ring.
Sorry don't have a diagram handy, but someone here surely will.
Hi, Thanks for the words... Do you ground the wires at all? If so, where? ... Like, an RCA left and right will each have a hot wire and a ground. I think I understand where the hot wires would go, just where would the grounds be soldered to?
