2A3 SE parafeed with PP-transformer
revintage said:
The 6B4G grid is at ca 200V potential.
So the cathode is about +250. I'm having trouble visualizing what
happens to the voltage at the MOSFET drain. It must swing opposite
the anode voltage. The reason I ask is that I think you will need
headroom for the drain swing negative equal to anode voltage
positive swing and MOSFET voltage rating to accommodate positive
drain swing equal to the anode negative swing, e.g. about a 500V
MOSFET. Is this correct?
Michael
PS the anode voltage rating on the 6S45pi data sheet is given
as 150V "Limit Value". Any idea what the real max anode voltage
op point is for these?
The top end of the drain winding is ultrapathed to B+,
and varies barely any more than power supply ripple.
The drain end sees its own quiescent voltage, minus an
opposite swing of whatever might happen at the plate.
The plate winding may bootstrap itself to swing not
more than twice the plate's quiescent voltage drop.
Yes, it looks like it should operate at about PS midpoint for best
efficiency and balanceds swing on both windings. Nice indeed for
direct coupling also! Just about the right grid voltage for the driver anode.
Only one thing left to think about... How to drive that MOSFET with
an anti-triode signal current mirror. Is it time for the Hall effect
coupling yet?
Michael
L12 + C7 try to keep the drive signal common mode to GND.
But the Ultrapath and CCS float entire output on B+ noise.
Could PSRR improve to drive in common mode with noise?
Rather than waste extra parts to oppose it with L12 + C7?
Examine Loftin-White input stage, as abused in my example.
Hard to tell my intent from the schematic alone, cause I
didn't bother to fill in all the component values. Four things
are supposed to happen simultaneously at input cathode:
DC Bias (obvious)
1/Mu gain degenerated by cathode resistor
1/Mu gain regenerated by positive feedback
1/Mu sample of B+ noise
The net effect at the plate is full Mu gain as-if no resistor
at the cathode, and drive signal fully common to B+ noise.
Or you can abuse pentode, cascode, or sand to get the
input's PSRR as awful as possible, which is actually good.
Its good when output also happens to float on ultrapath
noise, as both your and my example do.
You don't need any Loftin-White style feedback with the
high impedance devices, only applicable if you choose to
stay with a low impedance single triode. Doing both is
unnecessary.
Received the toroids for this and other projects from Antek today. Back to the original idea with the CCS(now hybrid MOS/BJT) on top as it has far better PSRR. Also with resistor-load on 6C45 you get distortion-cancellation that can be fine-tuned with R22.
Again Herr Besserwisser,
I have kindly asked you before not to participiate in my threads. Please respect this! As you have nothing to add about the original subject, why do you interfere? If you don´t like my attitude please contact an administrator about this.
antek transformers
revintage,
just found this thread, and have wanted to try a small tube amp, this looks like a good try and a great learning experience.
now, i apologize for my newbie status, particularly on the issue of transformers, but can i ask -- the antek transformers are 'power transformers'? with dual 115v primaries and a 6.3v secondary? this is what you are using? the primaries link the tube to the load, and the secondary goes to the b+? do you have a part number for the transformer?
do i have that correct? (again, apologize for the level of the question.)
i'll do the required reading on the parafeed circuit, but i thought i might have some transformers like you used, and that could get things off the ground without having to buy a whole bunch of stuff.
thanks,
ron
Just checked the Antek AN-0206, 25VA, 6V and it was extremely low compared to Talema that are 6,8V. It was 6,1V unloaded and with 2.8k:8ohm for 115:6,1V there is no need for unwinding😎.
Remade a pair of Talema 50VA 12V for the SEPTOR and had to unwind 2*14 turns to make it a 3k:8ohm PP.
Hi Ron,
Reread your post:
The two primaries are series-connected in anti-phase to B+(with only the lower as tube load) and the two secondaries are parallelled at the output.
But do not try it yet as this is still a prototype based on the schematic in post#47.
That seems an awfully small number of secondary
turns to justify tearing apart the factory wrapping.
Suppose one added an extra 28 turns wired up
the "wrong way", does it have the same effect?
