28 gauge shielded wire class D amp input
I am a beginning hobbiest mainly for class D amp build.
Where can I get a single 26-28 gauge shielded wire (similar to hook up wire) to be used for input from the RCA connector to the main board?
Can any of the CAT 5 wire be used?, any shielded and solid core?,
thanks,
You can buy the 28Ga wire of your choice and the braided shielding as separate items, thread the 28Ga into the shield, tighten the shield by gently pulling on both ends, and construct your own. Both are widely available.
You can also check the usual cable manufacturer's catalogs (Belden, Alpha, Carol. etc) to see if a particular part # fits your needs, and then Google search the part # for a consumer-level vendor.
You could also check the well known eBay vendor "John's Wire Shop" for some Mil-Spec communications wire that is a single shielded type in the gauge you prefer. He buys surplus spools from Boeing, manufacturers of civilian, military and aerospace craft in Washington State, USA.
There are many other sources. If you are finding difficulty sourcing your preferred cable, perhaps start by searching for some tips on using a search engine. I know that sounds condescending, but it's not meant to be ... search is a skill.
Not a particularly complex or difficult skill, but a skill none the less. If you find you can't find what you seek, then you need to hone that skill. Just like literacy was a critical skill in the 20th Century, search is a critical skill in the 21st Century. Learn it, or expect to fall behind.
By way of example, I found 10 listings for non-coax single conductor 28ga shielded wire at Digi-Key USA, it was the second result in a Google search. Figure out what search terms I used, and you are on your way.
Your description also practically describes Coax wire should you choose to use that; there are probably thousands of examples to choose from.
thanks for your input, I will get them ordered.
