25W/Ch valve project with Tamura, Tango or AN transformers
Hi
I would like to build a pair of low wattage monoblocks using Hashimoto, Audio Note, Tango, etc. transformers like the ones in the attached photos.
Are there any projects available?
355F1,
That looks like it might be a 45 amp; with 5Y3G; and 6SN7 or 6SL7 (or the Russian or Chinese "equivilants").
The output transformers are in the bottom.
That is a very nice amplifier!
Whoever built that amplifier did his own 2-tone crinkle finish on the power transformer (and either did the chassis too, or bought crinkle paint to make the power transformer crinkle to match).
It might be a traditional single ended amp, with air gapped output transformers,
Or
It might be a Parafeed amp, with plate choke and non-air-gapped output transformers all in the bottom.
We are talking 1.5 Watt or 2.0 Watt output.
It is not a 25 Watt amplifier.
What kind of amplifier do you want?
25 Watts per channel?
How heavy?
How big?
I recommend push pull, not single ended for 25 Watts . . .
(Unless you are very ambitious, and do not have a potential hernia problem).
Start with the requirements, then pick single ended or push pull, the output tube(s),
Stereo or Mono-Blocks (that hernia again), etc.
Then, we can see about what kind of output transformers are available, and/or recommended.
