250-300 watt power amp Toroids
900VA Toroids for high power amps
I have 3-4 900VA Toroids that have 2 secondaries; 58-0-58 AND 65-0-65vac.
These are unused surpluses from the Mackie 1400 power amp. Which is rated for 250w/rms 8 ohms or 300w at clipping 8 ohms.
$59 each plus shipping.
Mackie used the 58-0-58 taps with the output stage, but if you wanted more power, i.e. 315 watts rms or 400 watts at clipping, you could use the 65-0-65vac taps...
