25"
BassAwdyO said:
stephan,
Too bad they use hemp fiber and not the flowering top....
hemp fiber is high in the non-psychoactive canniboloids and not psychoactive THC.
Well, with the industrial hemp not even the flowers will get you stone, not enough THC, you`ll have to smoke half the field to get some effect. :dead: Not to mention how many loudspeaker cones you have to smoke to get :hypno1: ......😀
I just read that the new production 25" hemp unit will have XBL2 motor and 33mm xmax one way!
Very true. IIRC The proximity of the plants to one another causes a higher level of some hormones which increase the production of CBN (a canniboloid) and decrease the production of THC.
One reason they should legalize industrail hemp in the US(it cant be used on the drug market), asside from the economical benifit.
Hemp is just plain usefull anyhow. The fibers are extremely long and when used to make paper can be recycled many more times. Plus to make white paper it takes alot less chemicals to actually get the paper white. I've also read that hemp produces the greatest amount of biomass per acre to convert into biofuels, and it can be grown on the same plot of land year after year without degrading the soil like so many other crops
bassawdyo, im what some might say, relatively well educated on the subject, and was aware that hemp is too low in THC to produce a psychoactive effect...
...but come on since when did weed jokes make any sense in the first place?
also from what ive read CBD is one of the other psychoactive cannabinoids in marijuana, and may contribute to a quote "stoney" feeling.
but on another topic, i cant remember (teehee) who was talking about the massive fostex driver, but if you claculate it, when you have THAT much surface area, you dont need much excursion to displace huge amounts of air, besides by lowering excursion you need less windings on the VC, and as i understand it, that can make keeping a low Le for good transient response and high frequency performance, much easier. This could be wrong, someone please correct me if it is.
also, its been said(not sure how true it is) that moving a large surface of air gently sounds better than moving a small surface of air violently.
wow that post was riddled with uncertainty!
Exactly! Industrial hemp is the cure for many enviromental illnesses. For textiles it is much more enviroment friendly to produce than cotton, and is much stronger. Same for paper, hemp Vs woodfibre. It could save lots and lots of forest. Same with insulating materials, more enviroment friendly, probably also very suitable for loudspeaker damping. Hempseed oil has a number of health benifits, and can also be used for fuel after refining. And the list goes on and on.....
Buy hemp!😀
