DAD - DAD
These guys have been doing 384 for some time.
2L in Norway uses their kit for recording.
dave
- Fully Modular - 224 different configurations
- Sample rates and I/O structure can be upgraded
- From 2 to 8 analog Line or Mic input channels
- From 2 to 8 analog output channels
- 24 bit PCM sample rates up to 384 kHz
- DXD sample-rate: 352.8 kHz
- DSD sample rates: 64fs & 128 fs
dave
I just pinged him about it..George from the Audio-widget project is in the midst of making a UAC2 board with it.
see here
someone hasn't searched too hard if they're quoting Oohashi without mentioning the lack of replication, several lines of criticism easily found by just a little more search
no one is rewriting chapters in their psychoacoustics textbooks yet based on the "hypersonic effect" paper
it simply isn't "proved" that higher sampling rates are audible in music reproduction
I am quite sympathetic to the idea that there are technical reasons to want more passband to Nyquist margin than Redbook, but there simply are no recording mics, or loudspeakers with fc demanding >192 ks/s sample rates
the only reason to use > 192k would be to capture analog master tape bias frequency to apply Plangent Processes tech to peel off a layer of analog tape stick/slip mechanical flutter modulation
- Digital Line Level
- 24/192 basic question
