Guys,
with a 220 total budget
is there something that can be made to beat this
https://www.amazon.com/dp/B00MJ1YR8Y/?th=1
https://www.klipsch.com/products/R-12SW
DIY is fun and you get to learn so much strange stuff about sound and fall into a big rabbit hole of confusion with no ladder to climb out 👽
Can't beat the output per dollar ratio in the size range buying individual components.Guys,
Erin's Klipsch 12SW died some time after the tests, he recommended checking the return policy before purchase 😉
Buy two...
Lol,
My question was if armed with 220 bux in the wallet , you can source the components: driver , amp , wood , hardware , paint ....
To make more SPL at the same passband.
The design is open , can be anything ...BR , TL , TH, FLH , Bandpass....etc etc
"This" had a specific size, weight, and amplifier power.with a 220 total budget
That's different.My question was if armed with 220 bux in the wallet , you can source the components: driver , amp , wood , hardware , paint ....To make more SPL at the same passband.
As mentioned earlier, I don’t think that’s really going to be possible. Does it include cost of wood?
You could get a yung 300w plate amp for $150 which leaves 70 for a woofer. You can get a super cheap 12” GRS, but that leaves nothing for wood, glue, cabinet liner, etc. i’ve had people ask me about building a subwoofer for $200 and one as much output as possible. Every single time I’ve told them to go commercial. Unless you can find some secondhand woofers and amplifier
Dan
Dan
$220 is a pretty small budget, tough to beat the value offered by the large players in that form factor.
Don't get me wrong guys , It occured me if that was possible , it was the PAL12 or what design that fir 150 I think it was done but that was 2013 or 2014? , looks like after pandemic all got upside down, all doubled or tripled.
Looks like I hit a brick wall 🙁
maybe a table tuba horn sub if you build out of 1/2" mdf and use a cheapo plate amp (don't need more than a few watts anyway)
You could still come in around budget with big tapped horns, cheap drivers and low powered amps.Don't get me wrong guys , It occured me if that was possible , it was the PAL12 or what design that fir 150 I think it was done but that was 2013 or 2014? , looks like after pandemic all got upside down, all doubled or tripled.
The Totem Sub:
https://www.diyaudio.com/community/threads/10-plus-wood-18hz-isot-tqwp-sub.206955/
The Tub sub:
https://www.diyaudio.com/community/threads/500-diy-subwoofer-challenge.227541/#post-3321475
The Tub Sub did over 114 dB at 40 Hz using only 15 watts or so with distortion under 10% with two 4mm 10" drivers.
It's driver budget was $10, it would need to be a little higher to beat the Klipsch 12SW 😉
Plywood cost has gone up, have to use OSB to get the wood cost low enough to come in under $220.00.
Total build and finish time was around 8 hours back when I still could work half fast 🙂
Art
Klipsh diregardedCan't beat the output per dollar ratio in the size range buying individual components.
Buy two...
the infinity was the least or almost the least expensive and the best perfomer....but harman dropped it from production !!!!! WTF!!
so i guess the BIC will do but there was some 50hz resonance that the reviewer complain about...
if i get a BIC, remove the driver and stuff the interior walls with this
https://www.parts-express.com/Sonic...0mm-x-40-x-55-15.2-Sq.-ft.-260-566?quantity=1
It’s a little bit more expensive, but I would go with one of these as the cabinet liner, works wonderfully.
Dan
Dan
https://www.walmart.com/ip/Mainstay...3086199839&athposb=0&athena=true&athbdg=L1600
steal this pillow off your cellies bed, what Standing waves do you expect? 30cm/576hz?
(I thought the klipsch box was one foot sealed? maybe a bit bigger?)
Isobaric double woofer box
https://toidsdiyaudio.com/forums/discussion/iso-100-build-20hz-for-under-100/
klipsh have bad QC on their ampshttps://www.walmart.com/ip/Mainstay...3086199839&athposb=0&athena=true&athbdg=L1600
the one tested died when the tester fired it up
im looking at this one
https://www.amazon.com/BIC-America-F12-475-Watt-Subwoofer/dp/B0015A8Y5M
I need to study sealed boxes and half wave resonaces . All I’ve ever done is the 2 meter clear pipe full of styrofoam beads to watch the sine wave shape and jerk off 😝
You might do better with the ‘HE’ series of those drivers? (I think they might be newer than the video)
https://www.parts-express.com/GRS-1...-Excursion-Subwoofer-4-Ohm-292-818?quantity=1
- Subwoofers
- 220 USD budget home HT sub
