220/110 step down in reverse ... and more
I was looking for parts for my first project and stumbled upon an 220/110 step down transformer. I bought it as it was cheap and it had a metal cover and it was BIG.
Now the question.
Can i use it in reverse, as a step up transformer to get around 400v from it? The thing has 200VA.
This is the manufacturers page (Louth Transformer Company l)...but i'm not sure that it is an autotransformer(case in wich i guess it's compulsory to rebuild it).
Also here is the schematic for my first build. It's popular here. The guy says that a 220/9v trafo can be used as OT. Can i do that as a temporary solution?
http://www.lumeatuburilor.go.ro/ARITMA Stereo 6W/index.htm
Thx and sorry for the noobish questions
Now the question.
No. It's core will saturate. If fuses surviwe you'll get awful smell and probably flame.
You can, but quality of sound will be low: LF response because of low inductance, HF response because of high leakage inductance, and distortions because of DC current bias.
They will be temporary so quality won't be an issue(the ot's). The guy suggests to make an airgap between Es and Is. That i think will help with the HF.
Can you please tell me what should i look for? (VA rating, core area) I plan on rebuilding them at some point for use as an universal SE transformer for testing future projects.
Thank you 🙂
You can probably find some transformers from Telefunken, Philips, Grundig, and similar European tube radios. They are nice. Just look at e-bay auctions, it is what I would suggest. Edcors would cost you twice of their price shipped. But don't hesitate to make your first tube amp very nice sounding! 😉
It's next to impossible to find a low-priced set of OPT's in Europe. It's no significant problem if you want to spend upwards from $ 250 (Hammond transformers are usually obtainable here, although at higher prices than in the US/Canada), but if you're looking for something entry-level such as Edcor's cheapish models, then you're out of luck: it doesn't exist in Europe. At least, I haven't found it yet in the past 10 years. All you can get here is high-end stuff, which costs your liver and one-and-a-half kidneys, or the scrap stuff from old equipment you're referring to, but expect to pay insanely high prices for that as well. And usually you can only get one xformer, not a pair.
So using power transformers is about the only option you have if you want to start building tube amps at a low budget. But yeah, the limitations are significant. The best I managed was a stereo PP 6AQ5 amp, which has decent LF frequency response, doesn't suffer significantly from core saturation due to the low power level and PP design, but it still drops off beyond 8kHz. Some negative feedback could improve it, but I'd have to spend some time on optimizing it.
So for a learning experience, power transformers are usable, but they're not going to give you hifi, it's as simple as that. Nevertheless, they may very well give you the satisfaction of creating a tube amp that sort of works. I would strongly recommend sticking to a PP design though, so you can use unmodified transformer's. Something with a 2x115V primary and something in the range of 6 to 20V secondary is easy to come by and can be usable for low-powered PP designs using e.g. EL84's, EL90's/6AQ5's or any of the PCL triode/pentode types that are abundant.
Well the best thing i can do is to order the transformers from a guy here. The price is around 25euros. But i will try to make some of my own. I will eventually try to rebuild them interlacing the primary and the secondary.
About the PP design. That will be my next step. I hope to have a by-amped system in the near future. SE for mids and high, and PP for LF.
I hate europe in a way. everythings is expensive here. I'm a photographer sometimes 🙂) ...an boy ...i wish i could have acces to the low prices in the US. Same thing about cars.
Back to audio. Has anyone here made an open baffle ...with a spherical baffle? Half sphere that is*.
http://lh6.ggpht.com/_wUDOCViv9D0/Sx_R9NK-7QI/AAAAAAAAB7o/fx0r7-4QoLA/s800/blanda-matt2.jpg
Thanks for the suggestion! I wasn't aware of them; they do offer reasonably priced transformers. Judging by the limited data that is available on their website, their SE types might be comparable in terms of frequency response to Hammond's 125SE series.
Unfortunately, VVT seems to apply some odd exchange rates and S&H costs. A set of transformers listed at about GBP 36 for a pair would cost me in excess of € 110 (about GBP 95 at today's rate) according to their website. If they are comparable to an equivalent Hammond type, the Hammonds would still be cheaper if sourced locally. Better than a misused power transformer, but still no hifi. I guess mainland Europe is a bad place for cheapskate tube DIY-ers 😉
Not always ... I have a 55-0-55 power tools transformer wired backwards here that is in daily service. Although this is the exception rather than the rule.
Don't attempt to use an auto transformer though .. your HT will still be referenced to earth.
Back to back transformers work well.
