21" for CB
Better overall to buy relatively inexpensive higher Qt [4] 12" or 15" sub drivers whether put all in one place or preferably distributed around the room per Dr. Geddes.
GM
That idea crossed my mind as well. But if anything only two 12" would fit in the enclosure (at the front).
I wanted an enclosure that is max. 55 cm wide/high and 50 cm deep.
Then there is the amping. I would need a 2 Ohm stable amp, because the way I see it there aren't that many 8 Ohm 12".
That being said, I personally would prefer one driver (per side).
XX-21 looks nice - here's a 150 liter box 2 pi
That box is big for a low Q driver - 100 liter with a series 500uF capacitor gives the following
