Hello
Presently, I rebuild monoblocks Melos amplifiers. The output stage tubes are 6KG6/EL519 tubes driven by a mosfet follower. Between the mosfet followers and 6KG6 grids, there's 20K standard wire wound white ceramic resistors. This is the first time I see such a high value grid stopper resistors. Why they use 20K resistors ? (oscillation problems ?) During the rebuilding, I thought using standard value like 1k non inductive resistors. What do you think ? Thanks.
Not a common value, but there's only one way to find out if it's necessary.
Does the Mosfet have a gate resistor?
Yes, 2K resistor
Are you shure they are grid stoppers ?Hello
I think it is the resistor between source mosfet and negative supply.
Mona
Then I supose it's an amp with screen drive and the control grid on ground level.Yes, I'm sure. There's a 50K between source mosfet and negative supply.
Mona
Mona
Yes, you're right. So you have an idea why they use this resistor value ?
Seems it would cause high distortion in screen drive, which should be with a low source impedance.
That's correct. A driven screen must look into a small driver impedance to ensure screen current at all levels. A 20k resistor is contradictory in this instance.
Best regards!
Best regards!
No, but at least it explans the type of resistor.Yes, you're right. So you have an idea why they use this resistor value ?
Perhaps it's a mix of screen and control grid drive ? Without a schematic hard to tell.
Mona
Best regards!
Considering this, is there a value you can recommend me to try ? Thanks
Post the schematic.
Otherwise, it is like stabbing a gorilla in the dark.
And remember, not all schematics are correct.
If you wanted a direct drive on G1 to prevent blocking distortion or keep loading on a phase splitter to a minimum but didn’t want to drive too far into AB2 during periods of overdrive one might use a sizable grid stopper. I’m looking at that now driving 6550’s with 12BH7’s. 16.5k tail, 10k stopper. Why you would want a 5+ watt ceramic sand cast resistor would be a mystery unless it’s to be good and sure it never fails open and lets your tube redplate.
- Tubes / Valves
- 20K grid stopper resistor on output tubes
