2-way project: SS 2905/9700 + 18w8545-01
hi, here there is the correct position in my room and new simulation.
Does anybody have experience with these speakers xo?
Hi Luca,
I had a look at your project and came to the following assessment:
It's indeed difficult to get a better result with a crossover based on Troels Gravesen's CSM design. Inherently there's always too little baffle step correction and too low an impedance, no matter what you do.
A different crossover topology is required to overcome these limitations. :)
Hi Dissi,
thank you very much for your time!!....your xo is little complicated for me but i like it, specially on the woofer!....:up:....As you said, i copied "Troels Gravesen's CSM design" and try to change value for my box and room with boxsim simulation.:D
About low impedance, the specs of my amps (NAD326) say (theory) no problem.
About the diffraction i don't know if modify the xo is enough for best results.
For type of sound i prefer to emphasize the bass and little attenuate high frequency.
here there is your crossover in my simulation....:cheers:
Hi Dissi,
thank you for your great low-pass. it works very good also in my simulation;).
now i try to modify your high-pass for my preferences and boxsim simulation sistem (box, baffle and listening point).
What do you think about this?
Is the impedence good for you now?
bye
Luca
That's fine. :)
Tweeter level always is a matter of taste. When you hear the speaker you will know if it's right for you...
With "low impedance" I didn't mean an impedance too low for the amplifier, but the woofer is 8 ohm nominally and a low-pass filter that drops the speaker impedance to 4 ohm is a bit unfortunate IMO.
With "low impedance" I didn't mean an impedance too low for the amplifier, but the woofer is 8 ohm nominally and a low-pass filter that drops the speaker impedance to 4 ohm is a bit unfortunate IMO.[/QUOTE]
Thank you Dissi, now i understand your words about impedance.:rolleyes:...thank for your support. Do you have any other tips for my project?
Bye
Luca
