2 way BR/Horn System
Hi for last 10 yrs I was mostly with Fr fitted in BLH.
Onward I want to move into BR cab for bass, Horn for 500/600hz and above.
For bass I like cornwall/cornscala type cabinet of similar size, and install 850/950pb or FP HF200 in a 250/300hz Tractrix horn on top (not in the bass box) and 2 way simple passive crossover. My amp is 300B Se with 5 watt output power. Listening level is low to moderate and room size is 16'x27' where half of the room is for dinning.
This Ahuja Sound Solutions or this one Ahuja Sound Solutions is available locally, question is
Can I fit any of the above into cornwall or cornscala cab?
if not
What mod I need to perform to the cornwall or cornscala cab
OR
You suggest any other cabinet BR/slot loaded (like cornwall), T-TQWT, TL
which will play 35hz-600hz well.
Appreciate your input/suggestion.
