I want to build 2 subs and drive from 1 amplifier.
Which would give the best sound.
2 x 4 ohm drivers connected to give 8 ohms or 2 x 8 ohm drivers connected to give 4 ohms I.e series or parallel my amp can drive either.
Most amplifiers deliver more power into a lower impedance (unless they current limit), and more power gives greater headroom, generally perceived as sounding better.
Damping factor would be better at a higher impedance, but that would only be an issue with very long, thin speaker wire.
Forgot to ask.
If main speakers are ported should the sub(s) also be ported or does it not matter
