2" vs 1" compression driver
Hello all I realize this is probably an age old question, but I am somewhat of a begginer in the PA design world, and would really apreciate some help from the pro's!
I am trying to decide on a compression driver for my new cabinets (8 of them), which will consist of a 12" 400 watt front loaded driver running from 300hz up to the compression driver x-over point.
My decision lies in 2" vs 1". I am on a budget and the way I see it is that I will be able to afford either moderatly expensive 1" driver, or a lower middle of the road 2" driver. Right now I am looking at Selenium and Beyma drivers.
I would like to use the cabinets for meduim sized indoor and outdoor events (1000people). My concerns are projection distance and overall quality of sound.
If you guys could offer your opionions on this situation it would be a great help!
Thank you very much!
No one else had posted to this thread, so I thought I would post
haven't heard any of these but have been researching them recently so treat the info accordingly -
BMS 2" coaxial seems to be well respected for the money
Beyma CP385ND probably a little pricey but is a sweet sounding and pretty flat 1" driver.
I've been looking at 1" drivers and came across several posts that indicated the BMS sounds very good -
There are several guys around here that are pro oriented so you may get some more feedback.
Ken L
Hi Brett
You posted while I was composing mine.
Just curious, have you had a chance to listen to a Beyma cp385nd?
If so, wondered what your impressions were compared to the 380.
Don't see much Beyma stuff in the US, not much chance to actually hear before buying.
If I the cash had been available I would have already owned a pair of the 285nd's
regards
Ken L
It's a great driver. I've been using them on and off (mainly on) for two years, and when I finish the new flares they'll be back in service.
Based on my experience with the 4590 it should be excellent.
I technically own a pair of 380's (my friend won't return them; bastard) and they're the only one's I've heard from Beyma. But I'd expect the 385's to be similar.
When I get a bit of cash, I'll order another 380, or a BMS, for my bass guitar rig.
I usually find it better to keep lower vocal ranges out of compression drivers, and find 2" types too "barky" sounding.
Using front loaded 12", you can easily cross over to 1" driver around 3kHz or even 3k5Hz - box will sound smoother on vocals. For a 400W 12", a 40 to 50W compression driver would be fine, however if you will be using passive crossovers, some form of driver protection is recommended (a feedback squeal at high power will kill a compression driver quick!).
Cheers
Isnt 300 hz quite a bit low for a compression driver? With 1" drivers most commercially made PA speakers are X'd over at 1.5K or so, with 12 or 15" drivers. 2" drivers have great power handling but their extreme highs above 12K are limited.
2" Drivers seem to go down to 700 Hz or so, but 300 I think is way too low.
300Hz is only mentioned, as the low end of a 12" driver below the compression driver, so the CD won't be running anywhere near that low.
Agreed I wouldn't cross a 2" in a PA below 700 or so (except a couple of the Emilar and large Community drivers) but some of the better drivers will actually work easily to 400Hz domestically, loaded correctly.
In most installations, I'd agree, but IMO/IME it's the flare used, not the driver. Mosst truncated flares like the 2380 sound like shite compared to a properly designed multicell or radial. But the modern designs are smaller, lighter and easier to mould, so that's what's used.
Re: 2" vs 1" compression driver
I am running 6 selenium d205ti 1 inch exit 2 inch vc units.
Each is x'd over at 5Khz, 3rd order hp, and each are on a full bw 300wrms channel.
Sweet sounding..only had one fail on me in two years...
Seems they have a design flaw..the vc wire feeding into the coil is unsupported just where it goes into the coil itself, where it is embedded.. so, the wire is in the gap flux, but does not get support. So, eventually, flexure fatigue breaks the wire.
I detailed this to the selenium rep in the US, with drawings showing what happened, and how they could easily stop that failure mode...the rep yes'd me to death, promised me two replacement diaphram coil assemblies, and I never heard from him again..and no coils, either...Geeze, try to be nice...
I bought two replacement diaphrams, and repaired my broken one. Haven't corrected the other five, but haven't had any more failures yet..Course, I'll see what happens when my 17 yr old plays a party next week..the acid test
BTW, here's the drawing I sent them..
Cheers, John
There are folks running seirra Brooks Grand 32 tractix and TAD 4001's saying that they get down to around 300 to 320 -
I personally have not heard it done successfully, However, people I respect say Kevin Brooks's setup is nothing short of breathtaking.
However, that is lower than I would be wanting to try, if for no other reason than it is adding an octave to a driver that is already carrying (supposedly) 5 octaves.
regards
Ken L
The BMS 2" co-axial driver is wonderful It covers mid and highs, and lets you set your x-over point very low. Another good one to look at is the JBL 2445. They are floating around all over the internet, and I've seen them going for around $100 US.
Zach
Hi Jer !
My advise is to use for your project one of the best 2" driver at this moment : Selenium D3300Ti DPD
I have a lot of experience in Sound Reinforcement field and I think that is the best driver at a decent price .
For this driver the best high-pass crossover point is 800 Hz (pasive) 3th order with an 8dB damping.
Eight 12"+2" loudspeaker will cover with mid-high very well a show with 1500 - 2000 people .
