2 Passive speakers setup problem/question
I have 2 Wharfedale Titan 15 passive speakers, Wharfedale Amp CPD 1600 and Wharfedale Connect 502USB mixer. So I connected everything but when I play music sound is coming only thru high freq part of speakers and sound is terrible, woofer part is not emitting any sound on either speakers. I don't know if I explained good because I don't have much experience, so I am posting pictures of my setup and if someone can help tell me if i connected something wrong or it is something wrong with the speakers?
2 Passive speakers setup - Album on Imgur
i'll try.
can you tell me what the pin out of your 1/4 inch to xlr adapter is?
and do you own a multimeter (in case we have to diagnose the x-over in the speakers)?
what is the current setting of the mode switch on the amplifier?
You cannot connect a stereo input to a mono input channel, the differential amp inside the mixer cancels everything that is common on the two channels which is usually all low/mid frequencies. Instead connect to the USB input if using a computer for the source or connect to one of the stereo input channels(2/3 or 3/4) with a 1/8 TRS to dual 1/4 TS cable.
