All, this is a quote from pano from the Swap meet thread
"These were custom designed for the output stage of a voltage DAC. Core is 48% nickel.
There are 1:1 ratio with with a center tap on both primary and secondary. So you could have 1:1, 2:1 or 1:2 ratios.
These are PC pin types made for fit on a PCB. They can, of course, be hand wired.
I had these made by Bud Purvine of Onetics transformers. I have listened to and tested many transformers, the Onectics have always been the best I've heard."
Peter
Peter
