Hello, I'm thinking about splitting up a 12ax7 into 2 6av6's due to the fact in my Eico st70 the left and right channel share a 12ax7 in a gain stage, I'm not getting good seperation of channels when I turn my balance from left to right. Could this work? I checked the data on the 6av6 it does appear to be one half of a 12ax7. I do understand about the extra heater load. If it's not a 12ax7 problem, where else could I look to find this balance issue. When I turn it all the way left or right the other channel still has quite a bit of volume coming through. Any advise would help...
Thanks David
Thanks David
