Hi All.
I'm chasing for an affordable amplifier that sounds decent enough.
previously I used both the original t-amp as well as a trends audio and loved their sound.
I'd like to also being able to run a sub channel from the same amp.
I understand the TA2022 is bridgeable and could be used to use a sub as well as speakers but i'm unsure whether are any boards out there that do that,
does anyone know any readymade or boards using a 2.1 config and tripath or similar?
thanks
thanks
Have a look at this as it may be of interest
LEPAI LP-838 3 Channel Mini Amplifier w/ Subwoofer Out $13.30 Free Shipping @GoodLuckBuy.com
Also check this out Lepai LP-2020A+ Tripath Class T Mini Amplifier - TA2020 - Amp Bench Test - YouTube
there seems to be two lepai that do 2.1 channels. both the LP-838 you mention and the LP-168HA.
the problem is I don't think they have enough grunt to drive a 8" or 10" sub properly.
I'm not looking for ground shaking power, but just want it to move.
Check this
2.1 TPA3123
Is not a tripath... But similar... I Was thinking in buying one to try it... If any one has bought it could post his impressions..
2.1 TPA3123
Gracias danzz.
It looks good. Actually I changed the name of my thread, but unfortunately it hasn't updated it in the forum view.
I'm really after any chipamp that can do 2.1 or even a 4 channel amp, than can have 2 channels bridged should be fine.
The one you linked to looks nice. I hope someone can post some experiences.
It's a shame there are no more of these 2.1 amps around. I'm looking at using this for my TV, and connect it to a unpowered sub I had left over from my car install (the sub is fantastic and has a dual voice coil, but has no amp.
Having a separate amp just for the sub would complicate things unnecessarily.
Ok, some good news. I found this in another thread. It's starting to look VERY good.
shame it doesnt come with a DAC, but it has pretty much everything, including a remote!
Hifimediy DDX320v2 2.1 Digital Amplifier
There is also this below from a previous thread of mine on the same subject.
TDA8950TH 2 1 Power Amplifier Board 2 150W 250W | eBay
wow. I did not see this thread.
has a lot of info.
http://www.diyaudio.com/forums/chip-amps/229035-why-no-2-1-tripath-boards.html
Might follow it up there. as there was a lot of people involved.
has a lot of info.
- Class D
- 2.1 or 4 channel bridgeable amplifier
