Hi!
I need to build a high pass crossover for my mid-range and tweeter. (vintage University C-8M and T202).
My question is whether to use a single series capacitor for the tweeter and leave the mid-range uncrossovered; or to use the single series capacitor for the tweeter and a single series inductor for the mid-range. What difference will excluding the inductor make?
(probably: phase, peak in response at crossover point)
hi davidbosch
The first choice,difficult to be better.
The second will be better than if your drivers are at the wide band freguency have a flat respond.
thanks.
but does it make any difference in PHASE response at the crossover point with and without the coil for the mid-range?
do the two choices turn out into a 90° phase difference?
davidbosch Phase driver can change when the frequency change. it wants to use a measurement. i think the problem of your design is about break up cone. in the past i found the morduntshort ms 12(no xo for bass/midrange). but it didnot good. the transient was well but the sound had not soft davidbosch if your driver have the performance. you can try.
now i keep the links to you
http://www.royaldevice.com/laura.htm
http://stereophile.com/standloudspeakers/566/index.html
