1kW Class D
Pafi said:
There are some basic calculation rules.
thanks for that.
however, I fail to see how that helps substantiate your claim that
This is why the amp can't be loaded with lower impedance.
what exactly did you mean by that? if I load a 7.99ohm load to it (it is "lower" than 8ohm spec'd for the amp), would it explode? would it distort 10%? would it fail to produce any signal?
what exactly did you mean by "cannot be loaded", and how low is "lower impedance"?
Eva said:
Also, the power ratings mentioned in previous posts are just false. With +-60V rails and 95% maximum duty cycle only 200W are achievable on 8 ohms, and 400W on 4 ohms (multiply by 4 for bridged operation). That comes from some basic math that everybody should know before attemptiong to discuss audio amplifiers seriously. Some understanding of body diodes, Trr and Qrr is also required when it comes to discuss class D seriously.
The amp modifications needed to make tk2350 produce highest power include doubling the amount of mosfets as I've read (don't shoot the messenger...) from 4 to 8 mosfets....
The lower the load impedance, the higher the peak current the MOSFETs (and their body diodes) are required to handle and the amounts of heat produced.There is obviously a limit on the stress they can whitstand.
Pafi said:
I think you pointed an interesting and real phenomenon. I experienced a failure wich can only be explained by this. However I can't accept that an explosion can be occured without (at least local) overheating. 😉
Oh, "local overheating", I fully agree, I will try to remember that funny euphemism the next time that I have to explain a cracked transistor 😀😀
BTW: I'm working in class D full bridge fed with 300V to 400V and I experience that failure all the time with MOSFETs. I'm employing soft switching and di/dt is limited by means of a magnetic snubber, also the energy due to Qrr is returned to the supply instead of being dissipated. However, I have yet to find a MOSFET capable of surviving crossover times in the 50ns range (400V to 500V) after diode recovery, even Infineon "C3" series fail. Co-pack IGBTs perform just fine, though. I have just got some Infineon "CFD" devices to test (expensive!!)
I absolutely understand that and agree with that.
However, why was Pafi so sure that when a the amp cannot be loaded with lower impedance? how did he know that such a limited will be exceeded with an undefined impedance figure?
for example, is that limited exceeded with a 7.99ohm load? or 4ohm load? or 1 ohm load? or 0.1ohm load? Pafi hasn't been able to answer that and to me he could only be able to answer if he had tried his hands on the amp - something he apparently hasn't done.
All I wanted to know was what exactly did he mean by his statement and how did he learn that.
As I said: "There is no point in calculating exact impedance. It depends on cooling, type of audio signal, etc..."
I'm not going to calculate exact impedance limit (wich is a function of several variables) especially since I dont know the circuit. All I said that there is a limit, and this limit is strongly affected by Qrr.
Maybe Qrr is important for you but it isn't rigid here. My power stage is half bridge with additional diode. No more power lost because of Qrr. If amps are so easy damaged what is the purpose that we design complex protection circuit?
you said earlier and I quote:
so, doesn't that suggest that there exist lower impedance that when loaded to the amp, it will NOT cause the amp to exceed the limit and the amp will continue to work as designed?
if so, isn't that exactly the opposite of what you said?
Alternatively, find an amp that such a limit doesn't exist. If your earlier statement is true, it must be universally true and applies to UcD, NCD or any other amps and I didn't see you making that statement.
I am perfectly fine with making a wrong statement. Just clarify it and we move on.
