1974 Original Crown D60
Here I have a Crown D60. Dated 1974.
This has all original components including the electrolytic capacitors. Considering it's age it has impressive performance. DC offset is 0.001mV on both channels. THD measures 0.0027-0.0032% on both channels at 1Khz into a 8ohm load. Transformer is hum free and even the neon lamp still works. 47 watts into 8 ohm load at clipping.
I've always admired this topology from the designer Gerald Stanley of Crown. Patented class AB+B outputs run in a Class B. EF3 output stage. Quasi Comp output. Outputs only carry lower impedance, higher wattage loads. Only a very small amount of bias is running in the output transistors.
Very well made and easy to service.
I have many Crown amplifiers in my collection.
