18TBX100 with QSC RMX 2450 vs Yorkville ES18p ?
Hello, i currently have 2 yamahas DXR15s, and a (QSC RMX 2450 with no use).
And would like to add a subwoofer or 2, to my Setup.
What would you chose? and which would be louder?
A) Yorkville ES18P ( $1400 US ) Would have to sell the QSC Amp.
B) B&C 18TBX100 and QSC RMX2450 (bridged at 4ohm)
C) Two EV EKX18SP ( $1200 US )
Would like to know what would chose and why.
Thanks for your opinion.
The B&C drivers are likely to be much much better drivers than what are used in the commercial cabinets, so if you're any good at cabinet building, I'd go that route.
Make sure you understand the compromises you're making by running that (or any) amplifier at 2ohm on each channel (or 4ohm bridged).
Chris
B&C is a solid choice. If you're going to run them hard in a hot environment keep a small fan handy for the QSC for a little insurance.
Arrange ports on top and bottom to get some air circulation going. Don't skimp on bracing.
