~180v regulator schematic needed!
You can use the Simple series reg, it has been tested from less than 100V to a few hundreds volts (and simulated at up to several kV). It drops a few volts, but rather less than comparable alternatives.
I have also described some LDO HV regs, but they either require a PMOS, or regulate the negative rail
uh that sounds good. is there any schematic or link or thread or something about what you told?
